Thread: Pool pilot problem
    Aug 2015
    Kathleen
    1
    Pool pilot problem
    I am getting a "low amps cell?" Code on my lcd, cell find are straight and clean, the book says it's the cell, but this doesn't make sense because it looks perfect. Ideas? Unit is 7-8 years old
    Jun 2014
    Gulfport, MS
    67
    Re: Pool pilot problem
    It is probably the cell. If you got 7-8 years out of the cell then you did extremely well. You could chat with Josh over at Salt Pool Chlorine Generators l AutoPilot Pool Pilot | Cells | Parts | Systems - SaltPoolGuys.com and if it is a problem other than the cell he would probably be the guy that could figure it out.
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
