Results 1 to 14 of 14
Thread: CYA high after refilling pool??
    digidutch's Avatar
    Feb 2014
    Tampa Bay area, Florida
    15
    Had fiberglass pool resurfaced and filled with regular city water. CYA is over 100. I did not use pucks, no stabilizer added, waht happened? How do I fix, refill again?.... Thanks
    10000 Gallon, Fibretech InGround fiberglass. Sta-Rite Posiflow II cartridge filter. Baracuda G3 suction cleaner in skimmer port. Pump is 1 HP because needed extra power to get H2O up to Solar Roof Panels which we no longer have.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: CYA high after refilling pool??
    That truly makes no sense. There shouldn't be any CYA in city water. Please double check your mixing and lighting.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    there is no way just city water would have CYA in it.. where you able to see the black dot with the water all the way to the top?
    digidutch's Avatar
    Feb 2014
    15
    Saw black dot all the way. Is it possible that the chemical is old and not useable any longer?
    JoyfulNoise's Avatar
    May 2015
    13,247
    Did you fill your pool or did the PB do it?
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    you do realize that the scale is backwards, right? so if you see it all the way up it's <20
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by digidutch View Post
    This means < 20 ppm CYA (if crystal clear water, then 0 ppm CYA). So was this what you saw for the pool water? If so then you have 0 ppm CYA as expected. Why did you think it was 100?
    digidutch's Avatar
    Feb 2014
    15
    OMG I must be crazy.I totally misread. Will test tomorrow again but I think I was stupid, glad though it it's low, which it should be.........
    Thanks for putting me back into the real world
    30,431
    absolutely not. Yours truly misread it the same way about 9 years ago and others have reported the same.
    We are not alone, my friend.
    Sep 2013
    Connecticut
    728
    No need to retest city water for CYA tomorrow... Unless it's in the nature of a sanity check, of course ��.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    digidutch's Avatar
    Feb 2014
    15
    Yes CYA is LOW, so now want to raise it. Can I use pucks I still have to increase balancer at this point. FC 2.2, CC 0, PH 7.6, TA 70
    Jun 2014
    15,221
    Pucks do raise CYA, but a bit slower than if you added some granular stabilizer in a sock per the Poolmath calculator . Plus, you may find the sock method near a return jet is more predictable. If you plan for an initial target of 30, you will be very close to that target. For your 10K pool, that would equate to 40 ounces (2lbs 8 oz) of stabilizer in a sock.
    To increase CYA via granular stabilizer, simply place the required amount as calculated by the Poolmath calculator into a white sock and suspend it near a return jet. You can squeeze the sock occasionally to help it dissipate. Once dissolved, it may take about a week for the CYA readings to fully adjust.
    Sep 2013
    Connecticut
    728
    The trichlor pucks would be an awfully slow way to raise CYA, especially considering the amount of sun you get in your location. If you don't have stabilizer in the water, the sun will burn up your chlorine too quickly, and then the pool won't be protected against algae and other organics.
    You should add stabilizer directly. Most people use the granular product, put the appropriate amount in a sock, and tie it up near a pool return, where it will dissolve over a period of hours to days.
    digidutch's Avatar
    Feb 2014
    15
    Thanks for all the info
