Thread: Help. Replacing Hayward Muli port spider do i need to glue it?
    Aug 2015
    Boston, MA
    32
    Hi all,
    Replacing my 5th leak this weekend. I am having an aweful time because the spider gasket was glued in the multiport valve. Do I need to glue and or lube the replacement gasket?
    IG 15 X 30 Rectangle Vinyl Liner Built 1994
    Hayward DE 3620 Vertical Pro Grid
    AquaCal Heat Pump
    18K gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,629
    Re: Help. Replacing Hayward Muli port spider do i need to glue it?
    I have no idea why it was glued. Maybe it just seemed to be to you? I mean, it ain't like it's going anywhere! Clean that channel real well, lube that puppy up all over, and reinstall it.
    Aug 2015
    Boston, MA
    32
    Problem is it sits loose in the seating channel I can see it lifting with water flow
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by beantownace View Post
    Never done one myself, but the youtube videos and older threads frequently mention a couple drops of superglue.
