Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 97
Thread: Green swamp
    Aug 2015
    Parkersburg, WV
    51
    Green swamp
    Moved into a new house and the previous owner unplugged the filter pump two weeks before we moved in. I ordered the Taylor K2006 test kit and it will be here in two days. Get ready for some questions.
    Thanks
    13,300 gal; AG; Hayward sand filter model S180T; Hayward power flo pump 60 gpm; Hayward Aqua Trol salt chlorine generator; city water.
    Rusty
    Jun 2014
    15,212
    Re: Green swamp
    Kit on its way For now, consider adding about 1 gallon of regular bleach to the water each night just to keep things from getting too much worse. When you get your kit, post some good numbers and be ready to SLAM Pool School - SLAM - Shock Level And Maintain.
    More links to get you ready:
    Pool School - Chlorine / CYA Chart
    Poolmath calculator
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Green swamp
    Welcome to TFP!
    Congrats on the pool! You're off to a good start and you're in the right place.
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    Do I still want to add a gallon of bleach every night if I am running a SWG at 100 percent and on super chlorinate, or will that be too much?
    Jun 2014
    15,212
    Re: Green swamp
    Actually, no need to run your SWG at that pace. Stick just with the bleach for now and save some SWG cell service life. When you get your test kit and start the SLAM, you will turn it off anyways. I would suggest giving the SWG a rest until you complete the SLAM.
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    Sounds good thanks.
    Jun 2015
    Raleigh
    357
    Re: Green swamp
    Definitely turn the SWG off. It's much easier to get your pool SLAMed and then balanced just using liquid bleach, then turn the SWG on to maintain. The SWG requires some tuning itself with % and Pump run schedule so you want a good balanced pool where you can get reliable FC tests to tune in your SWG run schedule.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    Just curious how much bleach you think I might need for the slam?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Green swamp
    You should go to the store and get at least 10 gallons (or more) to get started.
    It all depends on your CYA level to determine your shock level for the slam.
    Make sure you stay ABOVE the shock level during the slam.
    I had a mustard slam once and I went through 39 gallons of bleach
    in a week and a half with a CYA of 70
    Dolphin E10 Cleaning Robot.
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    My CYA level is 55. I have a salt water pool. On the chart it shows my CYA needs to be 70 or 80. Do I have to raise to before I can slam or can I slam now. Ph was 8.0 I already got it down to 7.2.
    Rusty
    Jun 2014
    15,212
    Re: Green swamp
    You do NOT have to raise it right now. Start the SLAM. Adjust your new (target) CYA after the SLAM. Good luck!
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: Green swamp
    I don't have a salt pool, but it would be easier to SLAM with the lower CYA level. Once the SLAM is complete, you can raise your CYA. You can SLAM at either CYA level though, you just might use a little bit more bleach if you raise the CYA now.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    Thanks I will start the slam.
    Rusty
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    Here is a picture of what it looked like when I started.
    Rusty
    Jun 2014
    15,212
    Re: Green swamp
    Ooooh weee! That IS green. You will have some great before & after pics.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: Green swamp
    Jan 2014
    Buckeye AZ
    807
    Re: Green swamp
    It's like the grass just continues into the pool frame
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Aug 2014
    Northern IL
    4,615
    Re: Green swamp
    Eager to see those test results!!!
    Aug 2015
    Parkersburg, WV
    51
    Re: Green swamp
    OK here are some numbers. I am trying to keep the FC at 20.
    8/5/15. 4pm. FC is 15. CC is 2.5
    8/5/15. 8pm. FC is 10.5. CC is 2
    8/5/15. 10pm. FC is 19. CC is 2
    8/6/15. 9am. FC is 8. CC is 1.5
    I have to work a 12 hour shift tonight. Should I turn the SWG on to keep the FC up or have the wife add a gallon every couple of hours?
    Rusty
  20. Back To Top    #20
    Jun 2015
    Raleigh
    357
    Re: Green swamp
    Teach the wife how to sample and use pool math That's what I did and she did great. Empowerment is the best tool
    Do not turn the SWG on with elevated FC levels....there's evidence it could damage the cells.
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
