Results 1 to 8 of 8
Thread: Depth and diving board.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Is it not advisable to have a diving board on a 16x38 7' deep fiberglass pool?? I really want one, but the PB I think I'm going to go with does not have a FG any deeper than that and doesn't do a board with them.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Mar 2007
    Ontario
    211
    Re: Depth and diving board.
    Our bylaws for a diving pool are 8'. I went for a diving board but wish I did a slide.
    If kids are using the pool a lot , I think a slide would be more fun. I could'nt believe the price of a diving board.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    No kids for a slide. I was considering putting the board in after the pool was done, if that's doable. Might not be too wise though.
    Lynn
    Apr 2008
    Central Texas
    326
    I'm pretty sure that the recommended guidelines for a diving board are that the pool be at least 8 feet deep. There is also a spec for how far out from the end of the board that the depth must remain 8 feet. The guy we bought our house from said that he had found the guidelines and then went an extra foot down and an extra 4 feet out, just to be extra safe. The downside is that our pool doesn't have much of a shallow end.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks for the info. Might just put in a jump rock. Dang, I really wanted that diving board, but not enough to go with another PB or do a liner pool. At least I don't think so
    Lynn
    Mar 2007
    Ontario
    211
    If your the only person using the pool most of the time, you could do shallow dives.
    If your having people over take the board off.
    mas985's Avatar
    Pleasanton, CA
    11,741
    ANSI/NSPI-5 1995 guidelines do allow for diving depths of as little as 7' 6" for Type I & II pools but the envelope of the pool must meet other guidelines as shown here. However, you would then need to find a board which meets the specifications for that type of pool.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Wow Mark!! Now that's what I call an answer to a question
    Thanks
    Lynn
