Results 1 to 7 of 7
Thread: pH Constantly Rising
    Oct 2014
    San Marcos, Ca
    62
    I can't figure out why my pH keeps rising. I get it down to 7.4-7.6 but then the next day or two it goes up to 7.8. I'm putting so much acid in. Everything else seems good. Any thoughts?
    FC 3.5
    TA 70
    CYA 70
    pH 7.8
    12,000 gallon IG plaster
    Cartridge filter
    Intellifo VS
    EasyTouch Controller
    Pentair SWG
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Re: pH Constantly Rising
    Are you aerating in any way? Even unintentionally? Where are your returns pointed? If toward the water surface, consider pointing them straight out or down.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Mar 2007
    San Rafael, CA USA
    12,082
    Do you have aeration sources such as a waterfall, spillover, or a fountain? If you can turn any off then see if the pH rise is slower.
    Instead of bringing the pH down to 7.4, let it go to 8.0 and then bring it down to 7.6 or 7.7. You should use less acid that way and it may settle down in its rate of rise when it gets to higher pH. If it's carbon dioxide outgassing causing the rise, then it is slower at higher pH.
    If you are using an off-brand of bleach or lower-quality chlorinating liquid then these can contain too much excess lye that can have the pH rise over time.
    Finally, what is your Calcium Hardness (CH) level? Hopefully your saturation index isn't so low that your plaster is degrading. Do you see any Calcium Nodules?
    Oct 2014
    San Marcos, Ca
    62
    No aeration, I have a spill over but it's been off for a long time.
    I have a SWG so I don't add any chlorine.
    CH is 320 but that's the same as my fill water. I don't see any nodules.
    I will try letting it go up.
    Cartridge filter
    Intellifo VS
    Pentair SWG
    Mar 2007
    San Rafael, CA USA
    12,082
    I didn't know you had an SWG since that was not in your signature. SWG pools tend to rise more in pH in part due to the increased aeration from the hydrogen gas bubbles. Also, if you have a short pipe run between your SWG and the closest return, there may be undissolved chlorine gas outgassing. If you point that return more downwards, that might help. Finally, you can consider adding 50 ppm Borates to your pool. Though that may not lower the amount of acid you need to add, it should reduce the rate of pH rise and will help reduce scaling in your SWG cell.
    Oct 2014
    San Marcos, Ca
    62
    Sorry, I thought I changed my signature before I posted.
    The swg is on 20% and it's a long line to the closest return so I don't think it would be the bubbles.
    I'll add Borates and see how it does.
    Thabks!
    Cartridge filter
    Intellifo VS
    Pentair SWG
    Mar 2007
    San Rafael, CA USA
    12,082
    It can still be hydrogen gas bubbles since those will still aerate the water and not dissolve. It's the chlorine gas that in a longer pipe run should fully dissolve so wouldn't be outgassing. Anyway, the borates should help at least slow down the rate of rise. You should still target a low TA and higher pH as that is the fundamental source of pH rise from carbon dioxide outgassing.
