Ok, all this talk about DE made me curious and so I did a bit a checking..
~ Food Grade DE is made from freshwater critters and is considered safe for human and pet consumption as well as as an insecticide HOWEVER it is also much, much finer (smaller particle size) vs. pool grade DE.
~ DE used in pools comes from other sources (generally deposits of fossilized salt water critters), has a higher silica content, is heat treated, and has a larger particle size. This type is NOT for consumption and doesn't work well as a pesticide due to the larger particle size.
Because of the difference in the size of the particles, food grade DE generally does not work well as a filtration media (now I know) HOWEVER it can be used in combination with pool grade DE to help improve overall filtration quality even further.
How?
By adding it AFTER adding the pool grade DE.
The food grade DE is so fine that on its own, it passes through a DE filter's grids or the sand in a sand filter.. (Doh!) However, it ~is~ trapped by pool grade DE which means that it can be used as an enhancer for DE filters in much the same way that Pool grade DE can be used to enhance sand filters and it is actually marketed that way as a "DE filter enhancer" in some pool stores. Used this way it can trap the ultra tiny particles which are so fine that even pool grade DE can miss them.
So bottom line, no more food grade DE into the filter UNLESS it is goes in AFTER the pool grade stuff has been added.
Thanks Yeggim, without your comment I never would have started looking into this and doing the research into DE types.
So, back out I go to pick up some pool grade DE.
