When do you test?
Bigfish322
15
Pittsburgh PA
I recently received my TF-100 test kit and have been trying to first understand my levels so that I can adjust them. It's unclear to me WHEN the various tests should be done. For some background, I have a Pentair equipment... Superflo pump, Intellichlor SWG, FNSP 36 DE filter, Mastertemp 250 heater for a 16x34 vinyl lined pool. For the past two seasons (first two seasons) I ran the pump 24/7 and had the SWG set to about 18% (once things leveled off) and that seemed to keep things in check according to test strips. This season I was trying to cut the pump usage back to ~12 hrs a day... 6a-10a, 12p-4p, and 6p-10p and had the SWG set to 20% to start We're in Western PA, so we haven't really had much pool weather, so the auto cover has stayed closed most days. I was still checking the chlorine and PH using the K-1000. Both were off the charts. The chlorine side was actually orange instead of yellow. I uncovered the pool on a few of the sunnier days and then retested using the K-1000, but the chlorine was still off the charts. So I turned the SWG down to 10%. We had the cover off for 3-4 hrs yesterday, as it was sunny. Before closing the pool, I tested again with the K-1000. This time the chlorine barely showed any level. It was lighter in color than the first .5 - 1 range. Now I had been checking it daily. But the change from off the charts to almost non existent happened in 1 day. So, my question is, when do I test? What time of day? And do I try to get the levels about right until our actual pool season where we're in and have it open most days... and then worry about fine tuning?
Also, with a SWG... what levels do you balance first, second, third, etc.? Since some things impact others, what level is step 1 when looking at the overall health of the pool? Do you get chlorine right, then look at PH, or...?
Here is the official TFP position ...
For me personally, I place most of my emphasis on FC and pH. Those can change the fastest and have the most impact either for algae control or scale respectively, so might check those daily or every other day or so. With an SWG I'm very spoiled and go longer. :poke: TA has a wide acceptable range, so I might test that weekly. CH and CYA don't typically change much unless a lot of water was changed, so I just do those once a month.
Reactions: BMerrill
