So I bought a house with a chlorine pool that has Vinyl liner. It is attached to Sand filter and and pentair variable speed pump.
There are 3 PVC lines connected to the pump. Skimmer, Main, and Well point.
I was told that since i live in a low country in SC with a high water table and clay that I should run the well point during heavy rainfall.
I tried to do this yesterday for the first time..I turned my pump off and set the skimmer and main to OFF. I then set my filter to waste and turned the well point on. When I put the pump on and let it ran for 20 minutes no water came out into the pump. I was scared of burning the pump so I turned it off.
This morning I noticed my pool liner had bumps underneath it . It did not dislodge from the sides because I added last week a Pool liner lock.. Although I do see some bulging on the sides.
This morning I tried the well point again. but this time I primed the Pentiar pump. Now I see water coming out...
So when I run the well point do I always have to Prime it? Also when should i run the well point? In the middle of heavy rainfall? That will get me soaked? Do I run the well point before it rains even if it is NOT drawing water into the pump basket?
So confused on when and how I should run the well point.
