- Jun 30, 2020
- 2
- Vinyl
- Hayward Aqua Rite (T-15)
Our 16'x32' inground pool was installed in August of 2020 and we swam until around November with no issue and when closing the pool while draining we had our liner float. Our pool builder did our closing and he said at the time he thought the underground drain line we had was busted. They removed the water and dug a new drain line and we assumed the issue was fixed. When we opened the pool this year we had a wrinkle in the liner but we were not sure if that was from the previous issue or a new issue. I unfastened the liner in a corner and stuck a small hose behind the liner and was able to suck out water, so we have some water behind the liner. Its not enough water to float the liner while the pool is full. My question is what are my options for resolving this issue? There were not any measures taken during pool building process to negate water around pool so whatever can be done will have to be done after full construction and a concrete pool deck is poured around entire pool.
