Hi All,
We recently had our deck refinished and it rained directly after the concrete dye was applied causing the dye to run into and stain our pool. The guys just came back with the intent to paint the waterline area, so I drained about 2 ft for them to be able to work. The stains came up w/o the need for paint, but while they were in it cleaning, they found a "volcano" in the deep end where the transition slope meets the floor. It's pressed up from the bottom about 1" tall with 3 major breaklines about 18" across. Not losing water yet, but I'm sure that will happen soon. My pool builder thinks my draining 2 ft could have done it, I'm not so sure it isn't a root from the large tree that's 20 ft from the coping off the deep end. He thinks 8 ft is too deep for a root and the ground water "push" has done this. Either way, it's gonna cost big $$$ to fix. If it is a root, how can I ensure that the offender is permanently capped and won't regrow?
Russ
Russ
