Vacuuming and brushing during SLAM
jz2753
4
NE Ohio
Hi everyone, new to TFP here after experiencing cloudy water and learning all about CYA and trichlor tabs, which I’ve now ditched.
I’m part draining and refilling my pool to get CYA to a decent level. Once that’s done, I want to deal with what I think is algae. It’s greyish dust sitting in the liner seams, corners of the pool and a few blobs here and there. This stuff has been there pretty much since the pool was built 2 years ago, although it doesn’t really seem to have increased over the years. Just keeps appearing after vacuuming. The CC test seems to be around 0.5 and haven’t really done an OCLT because with my CYA so high I’m not sure my testing is accurate.
Assuming I have algae, when I come to SLAM, I only have an automatic robot vacuum, which I understand from this site is not good enough for dealing with algae. I see a lot about vacuuming to waste functions or backwashing, but I don’t think I have any or these functions. I’m a little intimidated by the manual vacuum with hose into skimmer route. What do you think about a cordless vacuum cleaner for use in the SLAM process? I’ve seen some YouTube vids with people recommending adding pool socks to the vac filter so that it catches very fine material including algae. I don’t mind spending a few hundred bucks on one of these.
Also, when it comes to brushing, are you supposed to clean/disinfect the brush each time so as not to reintroduce algae? How do you guys clean your brushes?
Tks so much. Looking forward to getting back on track and looking after my pool properly!
I assume that dust is dead algae, or maybe it is just dust.
Your robot is fine to use during a SLAM. Just make sure you also brush as well. The idea is that algae on the walls forms a protective layer you want to brush off so the chlorine kills it. No need to disinfect it between uses either.
If you had a ton of junk on the bottom of your liner you could vacuum to waste, but if it is just some dust here and there I wouldn't bother.
