Hi All..
Here in south alabama, for the month of june, we are up to over 6" of rain.
To avoid using my cya test kit so much can I estimate the cya based on salt level?
For example:
The measured salt level is 3200 ppm ±200
The measured cya is 70 ±10
In a give amount of time I measure salt to be at 2800 ppm
That's a 12.5% reduction.
Can I assume the cya has reduced by the same ratio?
Are there more factors to consider that makes this more complex?
Thanks.
For example:
Thanks.
