So, our pool is 20x12 ft. It is cinderblock rebar supported into the coping to allow for concrete expansion as ALL concrete wether cinderblock or gunite will expand and will in fact crack. So cracking isn't a huge deal but complete failure in 10 years is. So far our cinderblock is in GREAT shape. In your opinion, is it possible to pool plaster a cinderblock wall and have you seen what happens when you do? The bottom of our pool is vermiculite SAND. It isn't very much in fact I could probably shove it in a few days. The deep side is between 8-9 feet and the shallow end is currently about 3 1/2. There is no entry end either except to climb down our chrome ladder. I realize our filter and pump system would need to be gutted etc. also. How much work is this as far as cost altogether? Also we need to account for a poolhouse that is less than 1 foot away from the pool. We are removing the wall but it has to go right back into the same spot it was in (building codes). Is there new water proofing for such a construction? If so have you seen examples of this and know what it is called? I have seen dreamy photos of houses that are on the pool line before but I have no idea how they sealed that to make sure the wall did not get wet thus damaged. Were their walls made out of another material?
I have no idea how they do this any help would be greatly appreciated even before we get started in the wall. This is how close the pool house is roughly https://pin.it/3WTeVMm Here is another one it is literally on the water and this one https://pin.it/5n3mVzr
