I'm getting close to doing my plumbing upgrades, so I'm trying to get all the parts in hand.
Pic of current setup:
Although I'd rather replace the old gate valves on my setup, they work fine and spending $150 to replace them with Jandy doesn't seem worth it at this point (even if it would mean I could upgrade the cross piece to 2".
Instead, I'd like to just connect to the union that's glued into the cross piece and then use 2" pipe to connect to my new pump and filter and SWG.
I'd also like to use 2" pipe everywhere else, so I also need unions for the Pentair heater, and whatever they used on the waste and return lines.
Are unions compatible with each other? I've looked for markings on the unions, but most don't have any. The PVC all says IPEX, but most of the unions don't have markings. Can I use any Sch40 PVC Unions?
Thanks!
Thanks!
