Hello All,
Currently running a 3/4 HP 2-speed 115V motor. I'm interested in running high for 1/2 hour to an 1 hour on high speed then rest on low. High for better skimming action. I move approx. 45 gpm on high and 22 on low.
I've purchased a DC12v Multifunction Delay Timing on/off Optocouple Relay Module 30A Switch Timer
I've bench tested it, and it will work mechanically for what I want it to do.
When 115V is applied (from T101) timer it will power a 115V-12Vdc converter to DC 12V, and will also supply trigger signal, closing the relay switch (NO on) High speed will be on. Timer will be set for 1 hour to begin. When it times-out, relay goes back to NC (Low Speed), until the T101 Switches off.
I'm hooking High Speed to the NO contact and Low to the NC contact. COM will have the 115V from the output side of the the T101.
It will be housed in a 6 X 6 X 3 box with the 120V to 12V transformer. Weatherproof Electrical Enclosure Box Plastic NEMA 4 Clear Lid 6 3/4"x6 3/4"x3"
I think I'll have $25 in parts into it.
