Turning Off Cooling Function in Spa Mode
JupiterFL
128
Jupiter, FL
Pentair Intellichlor IC-40
I have an Intellicenter and Pentair UltraTemp 140 heat pump with cooling function. With the cooling function enabled it requires a set point for cooling in both pool and spa mode. Because of the spread required between the heat and cool set points, I am not able to bring the spa up to it’s max of 105 without disabling cooling at the heater setup first (max set point for cooling is 104 and it requires the heat set point to be a few degrees below cooling set point). Is there a way to set it up so that the cooling function is only available in pool mode so I don’t have to take the extra step of disabling cooling when using the spa?
Adding a clarification here and calling on @Jimrahbe
See photo. Is there a way to turn the cooling setpoint off in spa mode only, while leaving it enabled in pool mode? I’ve seen a photo of screen logic where it only had cooling showing in pool mode, but I don’t know if Intellicenter is different.
Thanks!
I dont have an ultratemp so I cannot test the theory but will the intellicenter settings (from the web interface not the app interface) allow you to duplicate the heatpump? 1 iteration assigned only to the pool circuit with cooling enabled and 1 assigned to the spa circuit with cooling disabled?
I have not tried that. Not sure i know how. I don't even see the heater in the web interface (or on the app).
I actually did ask the pool builder if he could link the same heat pump as a separate heat pump for the spa without cooling, and he said no, but frankly he's pretty new to the intellicenter. They had only installed a few so far.
Again, not sure if it will let you do this but intellicenter does support 16 heaters so maybe?
Login to intellicenter2.com
Hit the hamburger menu (three lines upper right)
Settings
System configuration
Other equipment
Heaters
Change existing ultratemp to circuit - pool
Add heater
Circuit - spa - keep cooling unchecked
Thank you for the help in navegating to the right place. I lost internet yesterday so wasn't able to try until now. When I add a heater and click on "type" for the heater it doesn't give me the option for the UltraTemp. I assume because it's already being used.
