Background-this pool is at a vacation home and I am only there weekends. I have lost the pool in the past and been forced to SLAM which I am looking to avoid, The best I can tell the pool is between 36-38K gallons. I have been managing to keep the pool clear but each year starting sometime in July I am running very high chlorine levels to compensate for the CYA build up since I had a bad experience before I knew how CYA affected my Chlorine. This is the main reason to want to change to SWG. I do skip an occasional weekend and I have a friend who watches the house and will dip strips, add tablets or shock when I skip a weekend.
A few questions:
1. I open my pool in mid March because I power wash and stain my deck yearly and need the house ready to go for Mothers day each year. When I open the pool its between 40-45 degrees will the SWG kick on at that low a temperature?
2. Can I use pucks after I open until its warm enough for the SWG to kick on?
3. Can I use powdered pool shock when a SWG is installed and running without damaging the SW Cell / plates if I need to quickly boost or sanitize the pool ?
4. Ideally, since I am off site quite a bit, I would like to be able to read the Chlorine level and control it from my phone via WIFI - is this possible? Not sure how much expense this WIFI control adds but I would like to hear both manual systems and WiFi controlled systems.
5. Is this a DIY project or do i need a company to install. I can go either way. I have an open 220v outlet at the pool equipment area.
I would like to go with the largest SWG so that I can run it less often, but still have the ability to turn it up when I want to "catch up" or solve a problem.
Would love to hear about brands you have used that you are happy with as well as those you have used that you are not happy with.
Open to all suggestions as I may have not even asked the right questions.
A few questions:
