Opened my pool in early may to calcium scale that trapped dirt under it. At one point the entire bottom of the floor and all of my steps were stained. Recently I lowered my PH to 7.2 and held it there for a week. I am making progress and I believe if I held my PH to low normal for the entire season, the pool would be clear. I am not that patient and want a clean pool sooner.
last night I added acid and brought the PH down to 6.9.
1. At 6.9 PH, am I at the point where I shouldn't run my pump?
2. Am I at the point where I should remove my stainless steel light ring and light assembly?
I have tons of, I assume calcium dust. I feel like my DE filter is not keeping it in the filter.
3. How do I remove the calcium dust?
I have read the Zero Alkalinity acid wash post. The Zero Alkalinity Acid Treatment
I have read the article 20 times and I do not know if it advocates doing a Zero Alkalinity treatment or not. It seems to be bashing the Zero Alkalinity treatment.
The gist of the article is add enough acid to get your Alkalinity to zero and keep it that was for 7 days. It will eat away 8 pounds of plaster and you pool will be clean, but it will be etched and cause you issues in the future. They surmise that 4 gallons in a 20,000-gallon pool with a starting TA of 100 will drop your alkalinity to 0 and your PH will be 4.5. Again I dont know if this article advicates for the procedure or not.
4. Is the Zero Alkalinity treatment a guideline or is it a sarcastic article bashing the procedure.
5. Has anyone successfully done a Zero Alkalinity treatment?
Here is a current pic. At one point all of the steps were covered in the stain. Keeping my PH an low normal has probably cleared 60% of the stain. The stains showed up darker in the pic then in real life.
