Pool Newbies here ...
We have noticed that our pool is losing water ... about 1" a day, so we've been having to add water each evening to keep the level up. Been doing this since last Monday.
Tested CL and PH through the week and levels were good.
Results today are off. (see below) Checked CL Tab Feeder yesterday and tabs were almost gone, so I added more CL tabs yesterday afternoon. Still surprised that we're not getting any readings for CL this morning.
We have someone coming out this week to try and locate the leak, so we can see what our next steps are. We're pretty sure its somewhere in the lines from the pool back to the pump/filter. When we filled the pool and it sat without the system being on, we didn't have the water loss issue.
Also - we have our pump/filter on 24/7. Should we leave it on 100% of the time, or should it be turned off at some point?
Per the results on the calculator, we added the recommended levels of Bleach/Shock and PH Down (acid) this morning. We're going to need to get baking soda for the TA.
If anyone has any suggestions/recommendations/advise, it would be greatly appreciated. Thanks! #feelingoverwhelmed
FC = 0
TC = 0
PH = 8.0
TA = 70ppm
CH = 120
FC = 0
TC = 0
PH = 8.0
TA = 70ppm
CH = 120
