I like my pool, and have used it before, but more recently, myself and others have just simply not used the pool in a while and I'd want to save money on the pool maintenance.
How would I go about temporarily decommissioning the pool for about 6-12 months? I've looked at the "Pool Opening & Closing" part of this forum, but I've notice that those particular threads are more-so for winterizing a pool rather than just simply temporarily decommission it during the upcoming next season. Could I still do a similar process to what I want to do?
Some things about my pool:
1. The pool is made of plaster.
2. The pool is mostly balanced, save for hardness being higher than normal, and PH being lower than normal. I was in the middle of adjusting these values, but then decided to temporarily decommission it anyways. Should I adjust these first to the proper value?
Is there any other viable solution to temporarily decommission my pool? I'd like to use it again in the future, but at the same time, still save money by doing the above since no one is using it at the moment, and probably for a while.
Thanks
Thanks
