Tear at main drain
pktaske
49
Monroe Township, NJ
I had to drain my 50,000 gallon pool to address my Paramount floor cleaning system. After fixing that and starting to refill pool, I noticed a 2" tear starting from under the main drain cover which sits in thd middle of the 8 foot deep end floor. Theres only about 8" of water in the pool now so I stopping filling and want to execute the repair. Water is a bit murky but I can make out things.
How do I execute this repair? I don't see screw heads on the main drain cover but I'll look closer tomorrow.
I'm also getting a bit of groundwater pressure but not much. Liner was lifted about 6 inches at bottom around main drain which probably caused the tear. Liner did not leak last year but it's definitely at least 10 years old.
Thanks....
Armed with a liner patch kit, you should see a couple screws that hold the drain cover in place. Once removed, you should have access to everything in that area. If not, post back and let us know. Good luck!
Excited Season 6 GIF by The Office
