- Jul 31, 2021
- 299
- Plaster
- Pentair Intellichlor IC-40
So my pentair SWG is fine when run at 20 gpm but above 30 gpm is starts leaking. I tightened the threads as tight as I could with hands and reset o-rings a couple times. I have some food grade oring lube I use for beer kegs. I am thinking of trying this lube. Any thoughts on other things to try first? Maybe need new o-rings but only 2 years old. If I get new o-rings I'm thinking silicon would be better the buna as they more compliant and should last forever.
Thanks
David
Thanks
David
