Suspended Calcium in Water
Maybe an obvious answer, but if you have calcium particulate in the water, does that count and contribute to your Calcium Hardness test results?
How do you know it’s calcium?
In theory, no. If you have calcium suspended in the water as calcium carbonate particulates, then it would not register on the CH test.
It's doubtful that it's calcium. Sometimes you can get calcium flakes out of a SWG coming out of the return.
What are your chemistry readings including water temperature?
It's probably not calcium. Is the plaster getting flaky? Check the cartridges to see if the particles are getting caught in the cartridges. If you can get some of the particles, you can put a drop of acid on them to see if they bubble, which would be consistent with calcium carbonate. You could also use some skimmer socks to see if you can catch some of the particles for examination.
I’ll check my Dolphin vacuum this morning. I’ve got ultra fine filters in it. You say just a drop of MA on whatever I can get out of them? The plaster is 10 months old. In my maintenance, there hasn’t been anything larger than let’s say powdered sugar sized material. If the plaster was flaking, what size would some of the flakes possibly be?
I haven’t brushed it in two days. With the light on, I went to the edge and rubbed my hand along the side. It was slightly slick and after my hand went across it, a milky residue could be seen mixing in the water. That’s what I think is clouding the water in general. Where my hand went across the plaster, it appeared slightly lighter than the plaster I hadn’t rubbed yet.
Quick question... If I have algae, would the FC not lower overnight? I just tested it and I’m still at 10 with CC at .5.
Not always, the CYA protects some of the FC from total annihilation (not a technical term ;) )
So that's why the shock level is higher than the target FC level.
FC/CYA Levels
CYA (Stabilizer)Minimum FCTarget FC**Target** Shock FC
4035-716
Bump/raise your FC to 16 and recheck in 1hr, see if that drops :)
