I have huge bubbles in my pump basket, my filter is gurgling/swishing, and I can actually hear the air bubbles coming out of 3 returns.
Here is what I have done so far to find the leak.
1. My husband checked and lubed all orings on the pump, Jandy valve, MVP, and any connectors with orings.
2. I checked for leaks using smoke and running water: pump drain, pump lid, any elbows/couplings/connectors with orings, skimmer, Jandy valve.
3. I injected dye beside every return and in the skimmer. I did not check the main drain. Water is too cold.
I will soon be redoing the plumbing that the last plumbers built incorrectly. It takes forever to prime the pump because the pipes are above the skimmer and about 28 ft from the pump. I specifically asked the plumbers if they understood pool plumbing. They said they did! I am replacing the plumbing myself this time. Fourth time in 8 years to redo the plumbing.
My pool plumbing is at the same level of the main drain because the pool is built on a slope. 3 sides are behind rock walls. Gravity makes it difficult to pump the water up to the pump, but if I move and I lower the pipes until I must go vertical, I think it will only leave about 7-8 ft to pump up to the pump. Less strain on the pump, and maybe I can keep some water in the pump when I try to prime it. Currently, 28 ft of pipe has zero water in it because the pump sits on the deck with the connections and Jandy valve 7-8 ft below. (The pump used to be lower too, until the lake flooded and put our 2 pumps under 2 ft of water for a month. It flooded again before we had installed a new pump, so we moved the pump to up to the deck.) Not ideal, but it is what it is!
on the deck.
I just realized that I did not check the steps, but I think the stairs would leak water, not air.
Once I redo the plumbing, I hope that stops the suction side leak. If it doesn't, what is my next step?
Thanks!
Thanks!
