OK, I just joined two minutes ago and am obviously doing everything wrong, like trusting the pool stores. The contractor who refinished our pool has given me advice that isn't always right, too and I don't know what to do now.
Pool is concrete, plaster replaced two years ago, and size is maybe 15,000 gallons. Color is dark grey, in full sun. Mid-Atlantic States location.. DTE filter, no heater.
Two years ago, I had our plaster replaced on a concrete pool. Last summer I ripped my shoulder brushing scale 2 X a day and finally loaded up with a Jack's magic cure and fixed it at the end of the season. As part of that mess, I drained half the pool and a week later the Ca was back where it started (700s). In retrospect, I think I had it too acid (at contractor's recommendation) for too long and just dissolved the plaster. resulting in high Ca.
This year, I was hoping for a worry-free summer. Instead I am battling green algae for the past month or more. No pool is worth surgery
Now, I have high cyanuric acid (90) and high calcium (510).
Phosphates is 300
Both free and available Cl were 0 yesterday when tested at Leslie's.
I was told to continue to use stabilized pucks in the floating dispenser and shock with 1 gallon of liquid Cl since both Ca and CYA are high. That is only abut 13% so I can't see how that is sufficient. I added a gallon, tested with reagents 1 and 2 (don't have a better kit) and it still showed zero Cl so I added another gallon and later a third gallon. So far since 9 am I have added 3 gal Cl. Also, a couple of cups of algaecide.
I have back washed 3 times today - every time pressure reaches 20.
Question for a Saturday night when no one is open, what now? Add more liquid CL? Leslie's said I didn't have chlorine lock with the test results they showed but earlier in the week, the hardware store's HTH pod tester said CYA was so high I should drain half the water to dilute.
Thoughts? Thanks.
Phosphates is 300
Thoughts? Thanks.
