I have the S7MD60, has been going fine for about 13 years. I have a problem now, and I'm sure the filter module needs replacing. It is 25023-0160s, although apparently 25023-0172s will also work in the S7MD60.
Is Sta-Rite still making the System 3 system? Or at least the filter modules?
Is it important to get a "fresh" module? What about one that is a year old but never installed? At what age of a never installed module would it be unwise to purchase? What is the life-expectancy of the module once it is installed (and properly maintained)?
This is more of a wanting to know, but why would you choose the -0172s over the -0160s, as it is about 40% more expensive for just 20% more surface area (72 vs 60 sq ft)? Do you then not have to clean it as often? Are you able to run the pump at lower pressure, and thus save electricity?
