Spectrum Amerlite (SAM) color wheel light Problem
wjr75
0
900
IL
Hello All!
I have a 10 year old Spectrum Amerlite (SAM) color wheel pool lite. It's controlled by a Aqualink RS8. It turns on for about 15 minutes and works fine. Then it turns off completely. It will then turn on again manually or by its self in about about 10-15 minutes. If anyone has one of these have you experienced this ever and what was the solution. Not sure if the halogen bulb is starting to go or if it's a over heat sensor or even the Jandy RS8 controller. Thanks in Advance.
