Solar heater Aqualink setup
NewPoolVirgin
3
California
We are new pool owners, first time starting up solar heater by ourselves. We have Aqualink automated system. Under My Devices we have added Temp 1 & Temp 2 set along with Solar Heater. Whenever Solar Heater is heating, Temp 1 always reverts to standby mode, even though the water temperature hasn’t reached the set temperature. If I turn off Solar Heater, then Temp 1 reverts back to Heating. Wondering if Solar Heater and Temp 1 are working against each other.
Anyone familiar with Aqualink that can shed light on this issue?
Aqualink prioritizes solar over Temp1 and Temp2 which would be gas or electric. I believe it is doing what it is supposed to do. I think if you raised Temp2 enough it would override the solar and kick the heater on. I see you have it set very low. That is why when you turn Temp2 off Temp1 kicks on. The differential is too great for solar to make up.
