Small Amount of sand in pool
tim86
0
May 14, 2017
44
Michigan City/Indiana
I just moved into current house and it has a 10k gallon pool, i emptied the sand out filter since was 4 years old or so and thoroughly rinsed everything out before adding new sand, going on 2 weeks since added new sand and having to vacuum pool daily and always small amount sand, using a vac with mesh filter so able see what all is vacuumed up, the amount if very small and mainly just collects on edges and on wrinkles in liner, with sand being new is this normal for awhile untill sand isnt as course? sand is Particle size (0.85-0.425 mm) and believe says on Hayward site they recommend .45-.55, is that .025 enough to cause it to slowly leak in the laterals? i didnt see any cracks or anything in laterals and the amount that goes into pool daily would barely fill a teaspoon if even that
