- May 28, 2022
- 4
- Vinyl
- Pentair Intellichlor IC-40
So I started my 1st SLAM today using all the tools here. My numbers were the following when I started:
PH = 7.2
FC = .5
TA = 70
CYA = 70
I added the dosage the SLAM table called for = 985 oz. to reach SLAM Target FC = 28.
An hour and a half later I ran 1st FC test and here's where I'm questioning my test kit/reagent or my intelligence. I pulled 10ml (.5 ppm) volume from the pool and added the 2 dippers of the R-0870 turning the sample dark pink. I started adding drops of the R-0871 and around 44-45 drops in the sample had a slight pink to it but not colorless as it has normally done under non-slam scenario. I stopped adding R-0871 at 90 drops (when I ran out mostly of patience and almost of R-0871). Is the 44-45 mark the best I'm going to get and the reading of FC (22.5)?
Going to need to go locate more R-0871 before I can continue either way.
Thanks for any help clarifying if I'm going about this in the correct way.
Greg
28K
SWG
PH = 7.2
FC = .5
TA = 70
CYA = 70
Greg
28K
SWG
