Hey everyone, Just completed day 7 of a SLAM.
Events leading up to the SLAM:
I have been battling algae for a while. Left for a couple of weeks on vacation and came back to a green pool with a dead bird in it.
Many bags of pool shock later and it would turn cloudy blue, but turn green again in a day or so. Didn’t have a real schedule or quality test. Switched from liquid to 1” tabs for a while to see if that would help. Test strips would always show barely any chlorine. Just kept shocking every few days. Added clarifier to try and remove the haze. Used a rechargeable hand vac to try and physically remove some algae. Gross stuff. Little red worms
in it. Had enough!
Fast forward to about 8 days ago and receiving a proper test kit for tfkits. My CYA was over 100. Took out the tabs. Did a partial drain and refill. My CYA is between 50-60 I suspect now. Maybe could be lower, but I went for SLAM.
The pool is looking blue again. No green. Lots of white bits floating still. Water still very hazy and cloudy. I lose visibility of the brush about halfway down into the pool it’s so cloudy.
I am brushing daily and blasting the cartridge with a hose once a day. The cartridge consistently has a kind of creamy white/light brown slime on it. Blasting it with the hose leaves behind white specs. Is it the dead algae? Chucked a new cartridge in just in case. The vac isn’t picking up any green algae anymore as far as I can tell. Whatever’s left seems pretty “suspended”.
OCLT yesterday was 1 PPM. Today was 2 PPM. But overall the pool is holding on to chlorine so much better as the days go on so I think I’m making progress. CC exists but looks like it’s consistently 0.5 or less now.
I know I’m close to meeting params. But the cloudiness doesn’t seem to be getting better.
Besides “keep on SLAMing” is there anything else I can do for this cloudiness? If the only parameter left is the cloudiness how long should I SLAM? Does cloudiness mean the algae will come back if I stop SLAMing and lower my FC? It feels like my little cartridge filter is slowly getting to stuff, but very slowly.
Pool
Build Type: Vinyl
Volume: 4025 gallons
Latest Test Result Summary:
FC: 23.0 (50 minutes ago)
pH: 7.4 (7 days ago)
TA: 70 (6 days ago)
CH: 100 (6 days ago)
CYA: 55 (7 days ago)
Test Results 10-28-2023 @ 08:32 PM
Free Chlorine: 23.0
Chemical Addition 10-28-2023 @ 06:41 PM
+ 41 FluidOunces of Bleach
Test Results 10-28-2023 @ 06:33 PM
Free Chlorine: 14.0
Chemical Addition 10-28-2023 @ 07:50 AM
+ 5.1 FluidOunces of Bleach
Notes 10-28-2023 @ 06:33 AM
CC - < 0.5
Test Results 10-28-2023 @ 06:32 AM
Free Chlorine: 21.0
Test Results 10-27-2023 @ 08:02 PM
Free Chlorine: 23.0
Chemical Addition 10-27-2023 @ 07:17 PM
+ 30 FluidOunces of Bleach
Test Results 10-27-2023 @ 07:07 PM
Free Chlorine: 16.5
Chemical Addition 10-27-2023 @ 12:55 PM
+ 28 FluidOunces of Bleach
Test Results 10-27-2023 @ 12:40 PM
Free Chlorine: 16.5
Chemical Addition 10-27-2023 @ 07:39 AM
+ 15 FluidOunces of Bleach
Notes 10-27-2023 @ 06:50 AM
CC - 0.5
FC - 19
TC - 19.5
Test Results 10-27-2023 @ 06:50 AM
Free Chlorine: 19.0
Test Results 10-26-2023 @ 10:26 PM
Free Chlorine: 20.5
Test Results 10-26-2023 @ 06:26 PM
Free Chlorine: 14.0
Chemical Addition 10-26-2023 @ 01:26 PM
Test Results 10-26-2023 @ 12:21 PM
Free Chlorine: 19.0
Chemical Addition 10-26-2023 @ 07:00 AM
Notes 10-26-2023 @ 06:42 AM
CC - < 1
FC - 19
TC - 19.5
Test Results 10-26-2023 @ 06:40 AM
Free Chlorine: 19.0
Test Results 10-25-2023 @ 07:50 PM
Free Chlorine: 20.0
Test Results 10-25-2023 @ 06:38 PM
Free Chlorine: 18.0
Test Results 10-25-2023 @ 02:18 PM
Free Chlorine: 14.5
Chemical Addition 10-25-2023 @ 07:40 AM
+ 51 FluidOunces of Bleach
Test Results 10-25-2023 @ 07:31 AM
Free Chlorine: 12.0
Chemical Addition 10-24-2023 @ 07:47 PM
+ 64 FluidOunces of Bleach
Test Results 10-24-2023 @ 07:42 PM
Free Chlorine: 10.0
Chemical Addition 10-24-2023 @ 08:06 AM
+ 49 FluidOunces of Bleach
Notes 10-24-2023 @ 08:01 AM
FC - 14.5
CC - 1
TC - 15.5
Test Results 10-24-2023 @ 08:00 AM
Free Chlorine: 14.5
Chemical Addition 10-23-2023 @ 08:29 PM
+ 46 FluidOunces of Bleach
Test Results 10-23-2023 @ 05:59 PM
Free Chlorine: 13.0
Chemical Addition 10-23-2023 @ 01:45 PM
Test Results 10-23-2023 @ 01:41 PM
Free Chlorine: 12.0
Chemical Addition 10-23-2023 @ 07:54 AM
Notes 10-23-2023 @ 07:14 AM
FC -13
CC - 1
Test Results 10-23-2023 @ 07:14 AM
Free Chlorine: 13.0
Test Results 10-22-2023 @ 07:05 PM
Free Chlorine: 17.5
Chemical Addition 10-22-2023 @ 06:28 PM
+ 54 FluidOunces of Bleach
Test Results 10-22-2023 @ 06:20 PM
Free Chlorine: 11.5
Chemical Addition 10-22-2023 @ 12:14 PM
Notes 10-22-2023 @ 12:08 PM
FC - 13
CC - 1
TC - 14
Test Results 10-22-2023 @ 12:07 PM
Free Chlorine: 13.0
Chemical Addition 10-22-2023 @ 06:47 AM
Test Results 10-22-2023 @ 06:46 AM
Calcium Hardness: 100
Test Results 10-22-2023 @ 06:42 AM
Total Alkalinity: 70
Notes 10-22-2023 @ 06:32 AM
CC - 1
FC - 9.5
TC - 10.5
Test Results 10-22-2023 @ 06:32 AM
Free Chlorine: 9.5
Pool
Build Type: Vinyl
TA: 70 (6 days ago)
Free Chlorine: 23.0
Free Chlorine: 14.0
CC - < 0.5
Free Chlorine: 21.0
Free Chlorine: 23.0
Free Chlorine: 16.5
Free Chlorine: 16.5
CC - 0.5
FC - 19
TC - 19.5
Free Chlorine: 19.0
Free Chlorine: 20.5
Free Chlorine: 14.0
Free Chlorine: 19.0
CC - < 1
FC - 19
TC - 19.5
Free Chlorine: 19.0
Free Chlorine: 20.0
Free Chlorine: 18.0
Free Chlorine: 14.5
Free Chlorine: 12.0
Free Chlorine: 10.0
FC - 14.5
CC - 1
TC - 15.5
Free Chlorine: 14.5
Free Chlorine: 13.0
Free Chlorine: 12.0
FC -13
CC - 1
Free Chlorine: 13.0
Free Chlorine: 17.5
Free Chlorine: 11.5
FC - 13
CC - 1
TC - 14
Free Chlorine: 13.0
CC - 1
FC - 9.5
TC - 10.5
Free Chlorine: 9.5
