- Jul 8, 2013
- 94
- Vinyl
- Jandy Truclear / Ei
Happy 4th of July!
Long time lurker and BBB practice follower here. We just inherited a 30k IG pool with the purchase of our house. Finally got all moved in on 6/30 and was able to remove the cover from the pool. There was some algae on the bottom and sides, but it wasn't a green swamp. From what I can tell, the previous owner didn't know what he was doing. These are my initial results with my trusty TFT100 kit
FC - 0 (expected)
PH - <6.8
TA - 0 (went immediately red, forum says that means my PH was 4.5 or less)
CH - 50
CYA - 100 (sigh, we've got a tablet user here!)
So on 7/1 i loaded the truck up with bleach from Wally World and got my FC levels to 39 as directed my PoolMath. Monitored that and kept it there, while brushing the pool. Also vacuumed some to waste before bleach addition since I figured i could use some water change out due to CYA. I also added some PH up as directed from a post from Chem Geek, to try to raise it from acid bath levels. Yesterday, 7/3, I vacuumed the bottom completely and backwashed the 60sq ft Hayward DE filter. From the morning of 7/3 to morning of 7/4 FC went from 39 to 33, no CC. This morning's test results:
FC - 33
CC - 0
PH - 7.5 (though i don't think that's accurate during SLAM right?)
TA - 110
CH - 50
CYA - 100
Given that my water is crystal clear and no CC, it sounds like I'm in the home stretch of SLAM. Tonight I'll do the OCLT to see if we're good. I just wanted to see if I'm doing everything right here. I've never had a SLAM process go so quickly
. Once SLAM is done, I know I probably should work on TA and CYA, though i'm having SWCG installed this week, so I don't need to go too much lower, maybe CYA 80?
Thanks for your time!
FC - 0 (expected)
PH - <6.8
CH - 50
FC - 33
CC - 0
TA - 110
CH - 50
CYA - 100
