- Oct 25, 2015
- 5,809
- Plaster
- CircuPool RJ-60 Plus
Folks,
When I went through recent lightning strike and subsequent self-inflicted short of the entire pool heater electrical I learned a neat little trick to solve the well-described ground issues that can cause the flame sensing circuit to fail. So I'm documenting it here to make it easily searchable. I found this documented on Fenwal's website technical support literature. Fenwal manufactures the ignition control module for many different pool heaters. Pool heaters often have a lot of ground wires that run from every different part of the metal firebox and sort of daisy-chain back to the control system ground. Problem is that severe service combined with a few small leaks can leave the heater a corrosion mess in short order. The ground system is a very critical component for heater control since it works by producing a tiny signal to ground and then the control module detects it to be sure there's a flame. This technology is incredibly reliable so long as the ground system has no interference from corroded wires. If it doesn't detect this tiny signal (about 2 millionth's of an amp) due to corrosion the system will keep the gas valve closed. To positively fix this you just run a wire from the burner base or from the burner flame holder on many of the new high efficiency heaters to the ground connection on the control module.
Pentair actually sells a ground wire kit to accomplish this. Here's a photo from their kit instructions:
Here's an alternate location (I added both on my heater just to be certain I'd have the ground signal):
I've attached a copy of the Fenwal technical article and the Pentair ground wire kit instructions.
I hope this is helpful.
Chris
Chris
