Should I bring my CYA up a little before closing at end of season?
Bevly
24
Wheelersburg, Ohio
Been checking my chems often due to vacuming due to digging nearby pond and lots of dirt/dust on the road and in the air. So, often have to add water with so much backwashing after vacs. My cya was at 35-40 range but now after weeks it is down to 20. Not sure if I should bring that cya level up a little more before closing when the season is over? Any thoughts on the cya level at closing?
IG with vinyl liner,18'X36" 23,800 gal.Hayward Sand Filter, TF100 kit, Cya 20, FC2.5/CC:0/TC2.5, Ph 7.8, TA 80, Calcium 100ppm
I don't really see any advantage to raising it now unless you have a bit on hand already, otherwise I'd wait till next year when you open.
I would suggest increasing your FC level a bit to about 4ppm and maintain that till covered and closed.
Maddie :flower:
