Safe to go in? Light tint to the water and chemistry balanced
manzalone
4
NJ
As the title says, the spa water has a slight green/blue tint. I've tried balancing everything, including a recent shock treatment. TA is low right now, but I'm wondering if I should just dump the water and refill or just get in it and say screw it. Got frustrated and brought a sample to the pool store and the metals content was also fine. Same recommendation as I had from my testing: lower FC, raise TA. What do you think???
Post full set of test results from your at home tests. My water looks blue from the reflection of the sky, or the AquaClarity. Phosphates don't matter in a properly chlorinated body of water.
