Hello… I am I the process of making my above ground pool into a semi inground. I am only planning to drop it the allowed 2 feet… my property is flat and after about 1 foot… the soil has sand. I was told that I don’t need a retaining wall. Then someone said that I had too. Another person said it should be ok if I left space between the pool and soil and not fill it with backfill…. My question is. It is a composite resin pool so I hope to get a decent amount of years from it. I also want to do it right and not have it implode , if god forbid when I change the line down the road. And if a wall is necessary. Would pressure treated wood be enough or do I have to go with cement blocks…. My original goal was backfill and then something around it so toys/pool stuff or even animals fall in between the space… any advice would be appreciated… thank you in advance.
