- May 7, 2021
- 61
- Plaster
- CircuPool RJ-60
Besides dealing with cracks, see other thread, got a question for everyone if I should have this wall wart removed or does it serve an important purpose to keep it around for ever?
So I have a plugged line near the pump area, I have this wall wart plugged in the pool and up until everything got demo'd I wasn't really sure where this lines runs to, why it was plugged and what purpose it served. Now that I can see the pipes above ground and what not, it looks like it runs to the plugged pipe near the old pump area. So I'm assuming it was never used as a skimmer alternative water suction pipe and maybe it was for a vacuum line. Anyway, I haven't used it ever, though that doesn't mean it's not important, my question to the folks here are, can I remove this and have them simply plaster over it to make it smooth? Unless told otherwise, my plan is to simply chip it out and plug it deeper in the concrete and then plaster over, one less wall wart to deal with. If someone thinks this is a bad idea, please chime in.
