We bought a fixer upper, and it took us a while to find a pool builder that was actually willing to work on our gunite pool from the 80s that has not been used in at least five years. We signed with a pool builder in Nov 2021. They installed a new pool pump and filter for us in Feb 2022, and then told us in July 2022 that they have closed down on their pool remodeling business. We had to look for someone else to fix the pool drain and resurface our pool.
We finally found someone who is going to work on our pool drain and install a new pool light before another contractor will resurface our pool for us. He also asked if we wanted to resurface and paint the pool deck, and install a small 5 foot tanning ledge which we agreed.
Here are my questions if anyone has any recommendations/opinion:
1) Tanning Ledge: Is the 5 ft tanning ledge too small? (Probably fits just one upright pool lounger?) Should the bubbler be right in the middle of the tanning ledge? I noticed that it might be not evenly 5ft in radius when I measured from the deck to the wood piece. One side may be 4-5 inches off. Should I insist that they fix it before they pour the concrete?
2) Pool deck: There seems to be a pretty obvious color difference around the rim of the pool deck. Is that normal? It has been a few decks. Do we have to pay the contractor more to add another coat of stain? (Just material cost or labor too?) He said there is two coats right now.
3) Stain on back patio: I know I made the mistake of choosing such a bright white for the stain, but I feel like they did not do a good job with the crack on our back patio. Am I being too fussy? It looks worst after they grinded into the crack and "patched" it before staining. Below are two close up photos of the crack.
Do I have to pay more for the contractor to sand/patch it a little more? Or is it simple DIY job that my husband can work on after?
Thank you for your time!
