I finished my SLAM Saturday, pool looks amazing. Here are my morning numbers:
FC 22. (Slam target was 31)
PH 7.0. Diluted test 1/4 cup each of test water distilled.
TA 80
CH 350
CYA incomplete ..ran out of R013.. have to run to pool store n get. I was checking again since I added last bit of refill water yesterday.
Once I finish CYA test plan is to let FC drift down to my FC/CYA target.
#1 How accurate is dilituted PH test..should I adjust up or wait until FC nears target below 10 to accurately read PH?
#2 Pentair Cartridge Clean & Clear 100 does a good job...usually is 18 start PSI. I did clean it this morning....has been looking great..PSI increased from 18 to 23 yesterday..thus the clean...when I put back in...start PSI is 28... no clue why...I started n stopped pump several times..bled air...nothing says high PSI...I'm left scratching my head...my CC has been at zero for 4 days...pool is clean..covered with Lanai...very little stuff to clog it...have added nothing but chlorine in past 10 days...makes no sense...Thoughts?
Thanks
Ed
TA 80
CH 350
Thanks
Ed
