Good call on the poolmath
You can toggle on “sharing” in the poolmath settings and we will be able to see your logs through a link without you having to post them. (Click my avatar to see mine)
Its safe to have fc anywhere between minimum and slam level for your cya.
- "Min FC" is 7.5% of the CYA level
- "Target FC" is 11.5% of the CYA level
- "SLAM FC" is 40% of the CYA level
A couple issues arise with cya so high though…
If there’s an algae problem its quite impractical and expensive to treat it properly (do the slam process)
At maintenance/target fc levels above 10ppm it skews the ph results which means you are torn between accuracy with ph and sanitary conditions.
The sooner you perform a water exchange to get cya down to a reasonable level the better as it will result in a much simpler path.
Do the diluted cya test procedure as poolstored linked to get a better estimate on how much water you need
Can't see them. Are you using the same login/pw as TFP?
Also see post #10
I think i set up everything correctly but I must be doing something wrong. Yes I have the same log in. In fact, I didnt even realize there was a TFP app so I just installed it. I've been just using the Pool Math app and going to forums and pool school that way. Any other ideas of what I'm doing wrong? I did a search in the app and I think i have it set up to share.
