Question for Easy Touch Programming Experts
Fins
0
Jul 14, 2016
30
Boca Grande, FL
I recently got my spa working correctly and was wondering if it's possible to have 2 different pump speed settings for spa operation. Here's what I'm wanting to do:
1. When I put the system into spa mode, I want the pump to ramp up to 3400 RPM and remain there.
2. When I push the button to turn the blower on, I would like the pump to drop back to 2700 RPM.
3. When I turn the blower off, I would like the pump to ramp back up to 3400 RPM and remain there until I change back to pool mode.
Is there a way I can program the system so that when I press the button to turn on the blower, the pump changes to a different speed?
Thanks in advance.
Set SPA mode to 2750 RPM
Create a SPA HIGH circuit at 3450 RPM
Assign the blower AUX circuit a pump speed of 2750 RPM(this doesn't really matter if the spa mode speed is already set to 2750).
When you put the system in spa mode, the valves will rotate and the pump speed will ramp to 2750. If you want the blower on, activate that Aux circuit and the blower will kick in, there will be no change in pump speed.
When you turn off the blower circuit the pump will remain at 2750 until you hit SPA HIGH which will ramp the speed up to 3450.
What makes this difficult is that you are wanting your spa mode pump speed higher than a spa feature pump speed. The Easytouch will always default to the circuit with the highest pump speed so you will have to turn off the SPA HIGH circuit before you activate the blower circuit.
