Hello-
I have a 16x32 inground pool with an 8' deep end. I have a side skimmer and a dual-main drain setup that Ys into a single pipe under ground. Both the skimmer and the main drain come back into separate valves and then combine into a single 1.5" pipe which feeds the pump. I typically try to push water out of my main drain with a shop vac each year, but never have I seen bubbles come out. I usually just pray its OK (and it has been for 5 years.) We live in Indiana, so I would really like to find a better way to create a good airlock with very little water in the pipe this year. What I would like to do is the following:
- Install an air valve into the drain plug hole on the pump
- Plug the pumps exit hole to the filtration system with an expanding rubber plug
- Close the skimmer valve
- Open the main drain valve
- Pump air into the valve in bottom of pump who's only place to go now is the main drain line
Will this work, and if so what PSI should I run the compressor at to be sure there is enough umpf to purge the line of water? My compressor will do 5.4CFM at 90PSI, but something tells me 90PSI is a bit much for the pool lines
Has anyone done this and can tell me what I should set the compressor at? Thanks!
ED7
ED7
