- Jun 15, 2009
- 8
Hi guys,
I'm confused and believe me it doesn't take much.
Here is my setup I have
1, Bombas PSH Mini-80 and its flow rate is here (I dont understand the graph
http://www.bombaspsh.com/image.asp?/adm ... age_serie/{40D925AE-0C9F-4940-831F-682D79BA3D4C}{A4B910A2-A5D2-4E48-B5B8-15E17D5B79CA}_ficha.PNG
2,Mega side mount 450 18" sand filter http://nbhengtai.en.ec21.com/Side_Mount ... 71950.html, the given flow rate is in Flow Rate (m3/h)
8.10
3, I at present have my pump 4m away from my pool and my Sand filter 6m away from the pump, would I be better putting the filter right next to the pump, so the pool water travels 4m to the pump and then once leaving the filter travels 6m back into the pool.
My concern with this setup is if the filter is too small for the pump what are the consequences of this, my pump seems to leak when running through this system but when run with just some pipe to and from the pool it does not leak, so I'm assuming the increased pressure from the sand filter and pipe run is causing an issue, now is it a weak link in the pump i.e. seal or is the whole system just pants.
cheers keith (Phew)
8.10
cheers keith (Phew)
