When pump is turned on it gradually fills up and fully fills up then a second later water starts to dissapear (air getting in)
- couplings tightened (lubed)
- drain plugs lubed
- pump lid with o ring replaced
- water poured over suction side with water hose to see if any leaks get covered
- everything on suction side lubed and covered with saran wrap and lube
suction side from ground is copper plumbing attached to pvc above ground
no water leak ..pool level same
anything im missing?
- drain plugs lubed
