Our motor bearings just gave out. I am currently looking for a replacement 230V Variable speed motor. I had replaced the original single speed with a Nidec Ecotech EZ when we first moved in. The Ecotech was a 1.5hp SF 1.60 230V variable speed motor which has now failed.
Pool Specs:
25-28K Gal
2" In/Out. Whisperflo pump.
Pentair Quad DE 100 filter.
No heater (Add in future)
Want to convert to salt in future.
Suction side Vac.
I do not have any automation. (Previous motor was programable)
*Pool refresh in 2-3 years, including increasing suction/discharge size.
I'm looking at Nidec Neptune motors and am wondering if I should go with the 2.7 THP or the 3.45 THP since it shows a higher efficiency.
Any advise or alternatives would be appreciated. Thank you.
Pool Specs:
25-28K Gal
Suction side Vac.
