Hello, I have an above ground pool with a sand filter. I am able to prime the pool on the filter setting and PSI reads about 12 PSI. While that is my normal clean PSI, the pressure out of the return jet seems very low compared to past years. Also when I try the backwash or recirculate setting, my pump loses complete prime (water drops spits out of the pump basket). I don't see any bubbles coming out of the return jet, and almost no bubbles in the pump itself. The only remarkable thing I noticed is that some how a bee was in the backwash viewing glass. Any ideas what could be causing the pressure issue and lose of prime when switching the MPV?.
