My pool light got water inside the casing somehow and blew out last time I turned it on. Do I need to replace the entire light/casing or just the bulb?
I tried to remove the screws on the casing and it's so tight and old (20+ year unit) that the entire the screw/bolt unit rotates and doesn't unscrew. Tried spraying some wd-40 with no luck. What are my options? I am trying to avoid spending $600 on the pool guy for this fix.
