Pool leaking
G920
1
Greece
Recently purchased a villa in Greece. We had paid for the pool drainage to be modernised to a drain grate which looks fantastic however we've noticed that the water levels are dropping a fair amount. We've tried to work out where the water could be leaking from however our tests have only caused more confusion.. When we move the pump directly into the drain, both the pool and the pump water levels stay the same, however if we pump the water into the swimming pool, the swimming pool water drops.. If anyone has had similar experiences or knows of any way we can find the leak it would be much appreciated. Difficult finding an English speaking pool specialist over here.
thanks in advance.
Welcome to TFP! :wave: Can you share some photos of your equipment and perhaps expand on what you mean by "pumping directly into the drain"?
Also be sure to update your signature with all of your pool and equipment info. It helps a lot later with posts.
Here's an article we also have posted that might give you some ideas. But we're here to help with any questions.
