Anyone have any idea how I can fix this? Pools two years old, and I've been unable to reliably get around this problem. The cleaner supply is on the same side as the steps, and if the "S" in the hose goes the wrong way, then the cleaner's backup valve cannot pull it away from the stairs. Once stuck, I have to move it, or even throwing the hose to the other side (reversing the "S") gets it happy again.
The backup valve does work, and pulls the unit out to sea just fine. Wheels are turning about 28rpm, and it works great until it gets stuck on the step.
I was considering modifying the backup valve to push itself sideways away from the wall a bit, which would require occasional re-orientation (if I figured out a reasonable way to make it go another direction).
Here's a photo:
Here's a photo:
